I need help desperately
Just how desperate are you.... ?//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
sometimes they'll put the labels for the wires ontop of the headunit, then go to your local car audio shop and get a wiring harness for your car, read the bag it comes in, and match everything together.
go to walmart or circuit city or best buy... buy a toyota wiring harness... now... take the harness from the kenwood... strip all the wires... and strip the wires on the plug you bought and match the colors together... anything that doesn't have a match tape it up... solder... or crimp the wires with connectors... now go plug that into the wiring harness in the car... take the brackets off the factory radio... and mount them on the side of the kenwood radio with the screws that came with the new radio... and remount the radio
If there is already a Kenwood wiring harness behind your dash see if it will plug into your current deck and all the features work correctly. The previous owner may have done you a favor without knowing it. Sounds like half your problem is already solved //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If it works take the aftermarket harness adapter back and stick those few dollars in ya pocket //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Oakey19
Oakey19
Lecanto Florida
tRiGgEr
BP1Fanatic
BP1Fanatic
