i need CVR kicker 12's!
not sure.. i mean at the speed lab in FL they have a buy one get one free going on now..
what kind of amp would push two 12's cvrs?
would a 1220 logic 2 channel amp work?
how much are the cvr's there? and i wouldnt suggest a logic amp. if youre looking for good budget stuff get a hifonics bxi 1206d. it will be a great match for the two CVR's. Make sure u get the dual 4 ohm subs. that way u can wire them at 1 ohm to get the full power from the amp
$150 for 2 cvr 12"s is a good deal but don't think it's actually buy 1 get 1 free lol. CVR's usually go for 80-90 a piece and they made that 150 a piece but get 1 free so you think they're actually 150 each.
how come i shouldnt get the CVRs that are 2 ohm?
that will put your impedence load too low. a bunch of amps arent stable if you drop the load below 1 ohm. if you wire two dual 4 ohm subs in parallel then u get a final ohm load of 1 ohm. (one dual 4 sub = 2 ohms in parallel. therefore, Two dual 4 subs = 1 ohm in parallel. the impedence is divided by two when you go parallel. in a series the ohm load is multpilied by 2 which will equal 8 ohms.) the rest is just simple math my friend. so unless you get an amp capable of handling a final ohm load of .5, then i would suggest just going with two dual 4 ohm subs. you can also go with TWO Single voice coil 2 ohm subs. but i dont really want to confuse you with the numbers. the people at the audio place should be able to explain it a little better than i can.
Florida13
www.gatorsportsnation.com
Florida13
Florida
adrian1185
