I Need a Box Built ASAP
eedmxee
Hey, I'm new here but i seen that ppl on here have the ability to build boxes and I need 1 asap so i thought i would start here. Here's what i need:
Ok I would like a box built to fit in the trunk of an 04 Escalade. I don't have da dimensions but i'm pretty sure you would know what i need. The box doesnt have to be super small cuz the third row is taken out but it doesn't have to be big also. I need it to fit 2 15" Alpine Type R's 4ohm load. The amp powering it is a bxi2008d Hifonics amp. I don't need anything fancy i just want it to fit in the trunk wit some kind of space left back there. Material or finish doesn't matter either but I would like for it to b gray like my interior is, and just produce the best sound output for my subs. Jus hit me back so we can make this happen as soon as possible. Also, some kind of handles that so that i can be able to remove and place them back whenever I wanted to! Thanks
Since most of us dont have access to an 04 escalade your going to have to supply is with some max dimensions, otherwise we would all be designing boxes that may or may not fit
Max Height
Max Depth
Max Width
Also do you want to go ported or sealed? Im going to guess Ported since you want sound output (spl) over sound quality (sql)
I understand but I dont have the access to measure it or the time really! I figured yall could just base it by the size of an average box that could fit in a truck or even the trunk of an average car for the width, length and height. For the depth i just want it to be enough fo fit the 15s but not too deep that it takes up alot of unnecessary space! I just figured someone here has done a box for and suv! I just want it fabricated to produce the best output for the subs! Ported Yes! but is sealed good or bad? I thought it was bad!
the time if took you to explain all that you could of taken three simple measurements. you also got to tell the people how much of the trunk your willing to use. 2 15s ported will take up allot of space. so you need to know how much its going to take up before someone builds you the box.
aight, i'll find a way to get it measured! I was sayin i don't have any type of measuring tape and to find some would be a hassle and take time, that i don't have right now. Being busy wit school and all but, if it's that important I will find a way to figure it out and get yall the measurements!
Well If you want the box to fit its important, so i guess its up to you, personally I wouldnt want to pay $200ish to find it doesnt fit so imo it would be worth it (but thats me)
I have a box that would work for you depending on your space requirements. its about 7 cubes after port tuned pretty low , i believe it was 33hz , would have to double-check. Sounds really clean and deep, and is an ideal size for the type r's i believe.. . It is around 39x20x22. In an escalade , it will definatly fit , but it is going to take a bit of room up, but i wouldn't want to go any smaller if you are looking for right size box for the type r's . It is currently uncarpeted but could be finished in carpet to match your interior. only problem may be shipping the beast, i am in upstate,sc.
eedmxee
eedmxee
Nashville, TN
eedmxee
