I,m getting a stroker.
I'm looking to get my first ever sub. It looks to be a 15" Cerwin Vega Stroker for -about $300 shipped. Here's the stats. I'm new. Tell me: good or bad
-Brand NEW, Factory box, never been installed, Not Refurbished
-Stroker 15" Dual 2 ohm Voice Coil Subwoofer
-Sensitivity: 86 dB
-RMS Power Range : 2000 Watts
-Peak Power Handling: 4000 Watts
-Impedance: Dual 2 Ohm
-Low Frequency response: 20 Hz
-High Frequency Response: 300 Hz
-Diameter: 15 Inch
-Field Replaceable Cone Assembly
-Ellipsoid Surround
-Integrated Voice Coil Heat Sinking and Modulation Ring
-Extremely High-Temp Dual Coil Design
-Dual Gap Motor Design
-Surround Clamping Ring
-Spider Clamping Ring with Integrated Speaker Terminals
-Axial Edge Surround System
-Mounting Diameter: 16.25" (412.8 mm)
-Mounting Depth: 9" (228.6 mm)
-1 Year Autosounds4less Warranty
I just emailed the guy and hes going to give me a weight and voice coil diameter. How does this sound?
hah the stroker is an SPL machine. It may not sound good on easy listening, but it will wow your friends for sure.
OK heres a thought. My dad and I are good with mechanics and electrical wiring and were installing ouselves. What if I also bought a second softer sq sub or a woffer (NOT A SUB-WOFFER) in addition and installed it on another amp and channel. I could play normal music on the soft side and then (if someone blares rap next to me) I switch channels to the stroker and play Bach's Greatest Pipe Organ Works to drown them out?
Whats the company website?
YES!!! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh: He asked it, alright!!
I stroke while Drift //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
killdevil fox
killdevil fox
Pumkin Peak, Appalachia
BrianChia
