i have problems someone hel[p
well i got everything in and installed but its keeps cutting in and out..i dont think i have the Bass EQ set right...amp is SAE 1200d...any help would be appreciated. green light on amp is on so its gettin power and ive already checked Remtoe and RCAs so thats y i think the settings arent right.
low input voltage? bad rcas? bad ground, make sure its straight to frame/chassis (wether or not you used it with other amps)
RCAs are same os my old ones too...guess i could switch em out and see if thats my problem. RCAs that are in it are Rockford gold plated ones. Wat should the EQ settings be on the amp? its almost like the majority of the tones are gettin filtered out or something...idk.
problem is with the amp..pulled the sub out to check tinsels and all that crap and checked VCs with the DMM and both checked out fine....then switched the amps out with my old faithful MTX Thunder 1501d at 4 ohms and it works perfectly.
heres a pic with wat the settings were on the amp...if anyone sees the problem LMK!!!
tylork92
tylork92
North Carolina
tylork92
