I have electrical gremlins
grampi
My '99 Corolla just started having an electrical problem. On my way home Friday night (I have a 5 hour drive from IL to OH on the weekends) I was listening to my audio system as I usually do. All of a sudden I noticed my Alpine head unit going through its power-off sequence (just the same as it does if I push the power button to turn it off) and then it turned off for a few seconds and then came back on, all on it's own. This happened about an hour into my drive. Then a couple hours later after it was dark, more things started to happen. Normally when I'm driving at night, I can see my headlights dimming if I really push the volume on my system as the amp I'm running can pull some pretty good current when the subs are hitting a bit harder. The dimming has never been severe, so I never really worried about it much. Now I'm listening to the system at a fairly low volume, the subs are barely playing, and my headlights are dimming so badly it looks like they are flashing on and off. Then just after this occures, the head unit shuts down again, then comes back on. Then I noticed if I tap my brakes, the headlights go completely out for a split second then come back on. My amp is connected directly to the battery and is fused right next to the battery. The head unit is connected to the fuse box and it too has a fuse in its power lead. I'm assuming neither power lead is shorting as that would cause their fuse to blow. I'm also not getting the relationship between the head unit turning itself off, and the brake lights momentarily killing the headlights. It almost acts like there's a weakness in the electrical system somewhere rather than a short. I wonder if the battery or the alternator is going bad? I would lean towards a bad battery as I would think a problem with the alternator would generate a check engine light, and there may also be another idiot light that would indicate an alternator problem. Plus I believe the battery is at least 5 years old. However, the battery always starts the engine without problems, and doesn't seem to struggle doing so. My symptoms are very strange and because of this I really don't have a clue what to look at for a remedy. What do you think?
grampi
grampi
Cheyenne
GhostMemphis
Mike Mccabe
Giles
    Jun 27, 2026
