i have a kicker amp question
yu12bme
I Have 4 15 Inch Kicker Cvx Subs (all Are 2ohm) And I Have 2 Zx 1500.1 Kicker Amps...is It Possible To Wire It So I Can Get The Full Wattage Or Since The Subs Are Already 2ohm The Load Impediance Will Dop To Low For The Amps To Work Properly.. My Ideal Was To Place 2 15s On Each Amp In Side My Armada Or How Should I Wire ..if Possible Need Suggestions Fast ..thanks
hold on wait, i figured out the double post thing, its because you have posted the question 3 times, but i read in another that these are dual 2 ohm speakers, the way i just said will give you a 1 ohm load, if they are all wired the same way(single sub parallel or series) you will have to use 2 subs on one amp and 2 on the other, you cant strap them, i would wire the subs all in series and then put 2 in parallel per amp for a 2 ohm load like the diagram on your other post
look at your manual for your speaker, wire it as the series sub which would make it a 4 ohm sub, then take 2 of them and hook both of negatives to negative and both positives to positive and do the same for the other amp
actually, you can strap the two zx1500.1's. however if all subs are dual 2 ohm, just wire two in series to get 4 ohms each, then wire them parrallel to the amp for a 2 ohm load. So you can wire two subs to each amp and get a 2 ohm load, which is what the amps are rated at.
yu12bme
yu12bme
HATTIESBURG, MS
t-money
vegang
vegang
