I give up!!!!
emsdad
Va
I have built 2 boxes and both are screwed. The first box was out of 1/2" MDF and not only did the box turn out like crap but the deminsions were wrong. I built the second out of 3/4" and 1/2" MDF and this box will fit in the space but I have more wood glue than wood..........lol. Can someone please give me some advice? I know that one problem is I am using a jig saw and it is next to impossible for me to get a perfectly straight line. I measure twice and cut once but it still seems I cannot get it right. I am a firefighter not a carpenter!!! The box I am trying to build is a wedge. Is there a program that I can put the dimensions in and it give me a blueprint on cuts, etc??
The dimensions of the box are:
16" Wide
15" Tall
8" wide @ bottom
5" wide @ top
HELP ME Please!!!!
It's not easy and you won't make a perfect cut with anything but a table saw or circular saw. Even with a circular saw, don't expect the cuts to be exact. Anything within 1/8 of an inch is not bad. You can always clamp panels together and then sand them down to ensure eveness. Don't worry too much about very small gaps. I would recommend using liquid nails. You can actually use that stuff to fill those gaps. It sets up nicely. Just use lots of caulk when done. Once you finish the box (carpet, or textured spray paint works very well), you won't see the imperfections.
Where in VA are you?
Might have some members locally to you that know a thing or two about woodworking //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
emsdad
emsdad
Va
JimJ
