i found some cheap powa
Clipping, in itself, does not blow subs. a fully clipped signal, basically a square wave, sent from a 100w amp will not overheat a 500w capable sub. The sub will happily fart along all day. Now clip the signal from a higher output amplifier, and the sub will overheat. The problem is overpowering, not clipping.
x2. It's not the clipped signal itself, but the byproduct (heat) that is associated with said clipping.
I don't understand why people continue to spend their hard earned money on dirty power. Sure it makes the sub move but there has got to be a reason why its half the price of other average quality amplifiers. I will drive around with no bass before I buy a pile of garbage like that.
FYI, a good install with proper tuning can sound fine with budget equipment.
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
DBBOOM
    May 31, 2024
    May 24, 2024
