i found some cheap powa
Yea cause clipping blows subs. //content.invisioncic.com/y282845/emoticons/slap.gif.87520e8ca8e90076ac30e777c0de5331.gif
It does. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Heat is the enemy of subs, and clipping causes a sharp increase in heat build-up...which can obviously cause some magic smoke.
Clipping, in itself, does not blow subs. a fully clipped signal, basically a square wave, sent from a 100w amp will not overheat a 500w capable sub. The sub will happily fart along all day. Now clip the signal from a higher output amplifier, and the sub will overheat. The problem is overpowering, not clipping.
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
DBBOOM
    May 16, 2024
    May 16, 2024
