I don't really know how to wire a setup like this:/
And good luck finding a true 2500 watt amp with only 105a(3x35a fuses) worth of power supply.
Most real 2k+ amps have current ratings of 200a and up.
Im not spending 2k on useless junk haha. I don't care. Ill buy anything.
---------- Post added at 06:12 AM ---------- Previous post was at 06:11 AM ----------
just watch the ohm load on your amp,, and give it a whack
Will do festiva. Thank you.
Bro, tone it down just a tad there lol....apparently you have some misinformation if you think that a protection circuit will stop clipping.
That amp is actually a very good, powerful amp.
And and every amp can and will clipp at some point. An amp that clipps dose not make it a crappy amp.(every one will do so at some point)
As far as $$$ not being the problem, that makes no never mind to me. I was just clarifying the clipping comment.
And I say what the hell, like you said, gotta try it at least once.
I was talking about 2000 watt amps(2k amp)
FIY, an amp rated at 2500rms with 3 35a fuses will be "useless junk"
And you may try running your 6500d at 1 ohm just to see. I have one that will run fine @ a one ohm sub. Of course after box rise, the amp is not quite seeing a 1 ohm load so yours may do just fine. That series of amps where hit and miss for running 1 ohms.
Just make sure you have good electrical for it and give it a shot.
Hell ya bro. Ya i guess its a good amp.
I was talking about 2000 watt amps(2k amp)FIY, an amp rated at 2500rms with 3 35a fuses will be "useless junk"
You like it? I smoked the fuses yesterday playing a song. I turned the gain down a little. same volume. Didn't blow. So I left it. And hmmm. Ill find a mono that can run 1 ohm.
DeathByWaffle
DeathByWaffle
Sheboygan. WI
DeathByWaffle
