I Came
Sony XM-2000R Output Power at 14.4V (20Hz ~ 20kHz):
2 x 300W @ 4 ohms (0.04% THD),
2 x 600W @ 2 ohms (0.1% THD),
2 x 1000W @ 1 ohm (0.1% THD),
1 x 2000W @ 2 ohm bridged (0.1% THD),
THD: 0.005% (1kHz, 4 ohm)
Freq. Response: 7Hz ~ 100kHz
Current Drain: 45A/ch @ 4 ohm, rated output
Dimensions: 29" x 5" x 18" (73cm x 12cm x 45cm)
Weight: 27 kg. (59 lb.)
Sony XM-2000R - CarHifi-Lounge.net
If I'm understanding this right, that's like 3:1 draw to output ratio, or am I nub tard?
Yes, it may be, however with the extreme power draw of the Sundown SAZ-4500D you have to have at least $500 in capacitors which are the only things capable of supplying the instantaneous power that it demands.
In other words, you need a minimum of 2 of these.
Amazon.com: XStatic 35 Farad Capacitor : SuperCap 100: Electronics
However, it's strongly recommended to run 4. If you have more than one battery you will not be able to run the Sundown SAZ-4500D, as it only slows your power down.
Yes, also If you have less than a quad VC sub to withstand the stupendous electrical surges, the amp will choke itself and lose output.
I'm pretty sure it's class a/b...
Ya it is, but dang, thats still helluva inefficiency lol.
Anyone planning on running these, make sure you get your flux capacitor first, and it must, I repeat must be constructed of unobtainum
Ya it is, but dang, thats still helluva inefficiency lol. Anyone planning on running these, make sure you get your flux capacitor first, and it must, I repeat must be constructed of unobtainum
no flux capacitor needed, just the lanzar optiplex, it produces 250 farads at 16v and it's only 720 dollars!
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
T.I.K.
