I Came
Suicide Bobb
SPLC Fails
Sony XM-2000R Output Power at 14.4V (20Hz ~ 20kHz):
2 x 300W @ 4 ohms (0.04% THD),
2 x 600W @ 2 ohms (0.1% THD),
2 x 1000W @ 1 ohm (0.1% THD),
1 x 2000W @ 2 ohm bridged (0.1% THD),
THD: 0.005% (1kHz, 4 ohm)
Freq. Response: 7Hz ~ 100kHz
Current Drain: 45A/ch @ 4 ohm, rated output
Dimensions: 29" x 5" x 18" (73cm x 12cm x 45cm)
Weight: 27 kg. (59 lb.)
Sony XM-2000R - CarHifi-Lounge.net
Like the Sundown SAZ-4500D, the most epic amplifier ever produced. This is the only way to rank up from intermediate to expert in car audio.
Yes, these Sony's would fry if they even came within the magnetic field the SAZ4500 that produces 7kw @ .5ohm at 17.9v.
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
T.I.K.
