amp choice help
Two 4 ohm subs can be wired to 1 ohm or 4 ohms. From your options, I'd go with memphis because I think it would perform better and you can wire it down to 1 ohms. As long as you set the gains properly, you can run any sub on it without blowing it. Check out the 12 volt website, they have a lot of good info.
Subwoofer Wiring Diagrams
But I do believe there is better amps out there that would get the job done. Anything from hifonics and audiopipe to audioque and sundown. Good luck.
whojohnjones
whojohnjones
mississippi
Phoenix Risen
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
