I am still confused
rgmatzke
After reading through the diagrams I still dont know which way to wire my subs to the amp. I am looking to get the most out of my amp and subs. I have a 2 channel amp which is stable at 2ohms when bridged and I have 2 Kicker comp DVC 2ohm speakers. Right now I have the amp wired in stereo and the subs parrallel... I think, because when I bridge the amp the fuses pop. So I dont know for sure the best way to wire my system to get the most out of it. Thanks and this is a great forum.
with dual 2 ohm subs, you can only wire to 1 or 4 ohms per sub, which means .5 ohms mono, or 2 ohms mono. You honestly need a mono amp that does power at 2 ohms. what 2-channel do you have that does 2 ohm mono?
I have a Fusion Power plant and I am not sure if it does 2 ohm Mono? I know it sounds really good the way I have it hocked up. So that is why it blows fuses when I bridge the amp? so should I wire the subs to 4 ohm and bridge the amp? I know once bridged it produces twice as many watts, but dont know how to wire the subs so the amp can be bridged and if it will benifit.
rgmatzke
rgmatzke
Hillsdale, MI
rgmatzke
michigan born
    May 14, 2026
michigan born
    May 14, 2026
