Sold I am looking for a mono 200w amp
I have a very nice Pioneer GM-X524. Here are the specs and a pic:
4 Channel Amlifier with built in Crossover
Specifications
Continuous Power (20Hz-20kHz, 0.08% THD)
4 ch: (4 Ohm) 50Wx4
4 ch: (2 Ohm) 60Wx4
2 ch: (4 Ohm) 120Wx2
Maximum Power (EIAJ)
4 ch: (4 Ohm) 100Wx4
2 ch: (4 Ohm) 240Wx2
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.004% (1kHz, 4 Ohm)
Signal-to-Noise Ratio: 105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10" x 2-3/8" x 12-3/8"
Features
Bridgeable 2/3/4 Channel Capability
1-Ohm Stable Operation
PWM Regulated MOSFET Power Supply
Balanced Isolator Input Circuit
Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs (x2)
Gold-Plated RCA Outputs
Hi-Volt Input Level Control (400mV-4V)
Speaker Level Input Adapter (included)
Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF) (Front & Rear Channels)
Bass Boost (60Hz, 0 to +12dB)
bumpinthanite
i like cars. a lot.
bumpinthanite
the hills of Michigan
fast1stgen
