Hybrid audio legatia 2 way car speaker system carbon edition se 4.65 inch
  • 2
TNT
St.Louis
Item(s) for Sale: Hybrid Audio Carbon SE
Speakers are in perfect shape, were just on display
The L4SE midrange/midbass is one of the best midrange produced in the world and available today.These are incredible audiophile quality speakers, any enthusiast would be happy to own. The sound quality is amazing and uncompromising. Perfect for European cars where restrictions are limited. Has carbon fiber cone with dust cap.
Specs:
Diameter: 4.65 inch
Mounting Depth: 42mm
Bolt Circle Diameter: 109.5 mm
Mounting Hole: 94.5 mm
Crossover Frequency: 150 hz at 24 db
Pnom Rated Power Input W/0) crossover: 35 watt
Pmax Rated Power Input W/0 crossover: 75 watt
Pmax Rated Power Input with crossover: 150 watt
Frequency Range: 135 hz-7500 hz +/- 3 db
Sensitivity: 91 db
Mms: 4.242 g
Cms: 300 um/n
Bl: 3.82 Tm
Voice Coil Diameter: 25.55 mm
Impedance: 4 ohm
DC Resistance: 3.2 ohm
Fs: 135 hz
Qms: 3.353
Qes: 0.789
Qts: 0.639
Xmax: 3 mm
Vas: 1.3 L
Sd: 5.281 mm
The L1V2 Tweeter is compact high resolution 20 mm soft dome driver that can be used as reproduction of treble frequencies in dedicated two, three or four way front stage systems. Has small diameter , very easy to install, has soft dome silk diaphragm and resonance frequency that is compilementary to all types of front stage system architecture. Can be listened to for hours without listeners fatigue while having industry standard response.
Specs:
Diameter: 55mm
Mounting depth: 20 mm from bottom of surface mount flange to bottom of open terminals
Mounting Methology: surface mount tweeter with three 3 mm screw holes to secure the tweeter body from the front
Construction: solid machined aluminum with integrated polypropylene rear cap and push terminals
Distortion: 5% max at rated power input no crossover
Magnet diameter and construction: 19.5 x 3 H
Recommended Minimum crossover: 3200 hz @ 24 db
Pnom: rated power input: 10 watt
Pmax: max power input: 20 watt
Pmax: with crossover 75 watt
Resonance Frequency: 1830 hz
Freqquency Range: 2500-25000 hz
Sensitivity: 90db @ 1 watt
Nominal Impedance: 4 ohm
Voice coil diameter: 20 mm
Q Mechanical system: 3.103
Q Electrical system: 3.553
Q total system: 1.656
Krm: 198.84
erm: 1.278
Kxm: 2.136 mh
Exm: 0.513
L2x Crossovers are vertically bi amped passive designed to work with any wide bandwidth Hybrid midrange. They are very nice looking, high performance filter set that contains hand matched high quality low tolerance parts such as metalized polypropylene capacitors , air core low ESR inductors and low tolerance ceramic resistors. Has tweeter protection circuit to defend the speaker from being over driven or from faulty amp circuitry and extreme input voltage. Double sided design with nickel plated spring loaded terminals for ease of install and adjustment of tweet attenuation.
$900
free shipping 48 states/ I will get you a quote for International shipping
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
TNT
TNT
St.Louis
Huckleberry Snd
SPLBassJunkie
    May 21, 2024
    May 20, 2024
