hum when rear speaker rca is connected
cmotavalli
4
nj
I have been trying to find out why I hear a hum from all my speakers when pressing on my brakes. If I disconnect the rear speakers RCA from my amp the hum goes away. I have now plugged in a ground loop isolator which is masking the problem but I am wondering what is causing it. I tried swapping the front and rear speaker rca from the amp and the sound comes back. Could it be the amps grounding, the rear speakers RCA, or a connection within the rear speakers themselves? Getting behind the radio to run new rca cables to test is not easy and if it could be the amps ground would rather try that first.
Thanks
a broken RCA (internal) can cause this. or it can be internal to the amp. verify if the hum is in all speakers or just the speakers assigned to the "rear" RCA?
He said it only happens when he hits the brakes, is the amount of current carried by the wires to the taillights enough to cause interference in the RCAs? If the RCAs are ran directly next to the taillight wiring it might be able to cause interference.
The noise is only when I hit the breaks and is in all speakers not just the rear ones. I will try to rerun the rca's but the rca running the front speakers isnt causing a hum even though it is run with the rear rca all the way to the trunk.
the brakes (and other things) can add noise on the ground system, and that noise can be amplified when you have ungrounded signals (since the amp and vehicle share the same ground plane.
if it is in all speakers but only when you use the "rear" RCA's, but not when you use the "front" RCA's then that points to an RCA with a broken internal lead, likely a broken connection to the shield.
i use a 2-piece head shell RCA's so i can look at and repair connections. the cheaper molded RCA head shells are not repairable.
cmotavalli
cmotavalli
nj
keep_hope_alive
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
