Hum/Hiss noise all gains down
  • 2
Hey everybody Its been a while since i posted. My new system starts with a Pioneer ???930bt multimedia headunit, which feeds a PPI DEQ31 EQ then off to a PPI FRX456 to a PPI PC4800.2 for my front stage with some cheap boss audio components. For my sub output the FRX feeds a Sundown SCV6000D running a pair of Sundown X-12's. I have 1 battery under the hood and 4 batteries in the back being charged by 3 OE 220amp hairpin alternators. this is all installed in a 2005 GMC Yukon. The noise is there all the time volume down, volume low, between tracks, on aux input with nothing plugged in. 4 1/0 positive runs to back and 2 1/0 negative runs to the back, several ground points front and rear. I can'T seem to get rid of it. I've been doing installs longer than some of you have been alive. This one is just giving me a headache. ps I'll post some pics at a latter time.
Start removing components from the system. Start by pulling the rca cables from the amplifiers. Turn the stereo on and see if the noise is still there. If it is, you have a bad amplifier or noise interference from a speaker wire , or a bad amp ground etc. Process of elimination till you find the problem.
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire around rca shield on back of head unit and attach to ground which may take care of it also.
I'm guessing that's what it is. There's not a lot of room back there.
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
I’ve got a 1500 watt amp and 2 kicker 12” subs that play a loud hum when I turn the car off. This note plays during the time between the engine...
Can you running optical into that Bit processor? Your main input for noise is going to be between the Bluetooth and the processor. If you have...
dmuney
dmuney
arlington WA
dmuney
DEW123
    May 7, 2024
DEW123
    May 7, 2024
