kile 10+ year member
cutlass
Will a 7 band equalizer give you that much more contol over the bass than a 3 band?
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gifBass frequencies is 80hz and below. Whether you have a 7 or 3 band adjustment, they'll probably only have 1 band to adjust below 80hz. What are you trying to achieve... because installs have more precedence over processing in any set up, unless you're worried about time alignment.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Huh?so will it make that much difference on the music?like on a 7 band bass setting and a 3 band bass setting
thanks man... that was over 3 years ago tho.... the newer mics are a little more stiffer, which probably suggested that the old mics were inaccurate. It was nice to hit that number at the time, especially for a sealed box and a legal reading at the dash. dingaling on the other forums hit 147 db with a similar set up using an Arc 2500cxl. Arc makes some pretty solid amps.hey vestax i just checked out your page, 140 w/ 1 idmax sealed is pretty D@MN impressive
