How would you wire these up?
madurodave
Please let me know how I should run these speakers and sub. Should I run the four sony speakers on the head unit and the tower speakers and sub of the amp? Should I buy another amp? Should I install all speakers on the amp?
I am so confused on what to do........ Thanks in advance for any advice you can give me.
Here is what I have to install on my boat.
Receiver: Sony CDXM60UI, 52W x 4 High Power -23.2 watts per channel continous average power into 4 Ohms.
Amplifier: Sony MX-604M, 4/3 Channel Amp, 600W max power, 60w x 4 RMS into 4 ohms, 70W x 4 RMS into 2 ohmsm 160W x 1 RMS into 4 ohms (rear), selectable 80 Hz HPF/LPF
Four in boat speakers: Sony XS-MP1620W, 45W RMS, 160 Watt Peak, 4 Ohms
Two tower speakers: Polk MM651, 100 W RMS, 200 Watt Peak, 2.7 Ohms
One subwoofer: Sony XS-L100P5M, 200 Watt rated, 800 W peak, 6 Ohms
Here's my 2 cents,
Connect your 4 speakers to the amplifier, two options;
1) one channel per speaker
2) Parallel 2 speakers; There are two options for this one;
a) Balance (Ex. Front Left + Rear Left = Channel 1) OR
b) Fade (Ex. Front Left + Front Right = Channel 1)
Either way you should get 2 ohms per channel and your left with two open
The open channels you can try to connect your 3ohm tower speakers, I wouldn't because your amp is only 2 or 4 ohm stable not 3. One could argue it falls within the amp parameters but if that were true then the specs would read 2-4.
Any Advance CA member disagree with me?
-Sub-woofer Options
Since the amp is neither bridgeable nor 6 ohm stable I would recommend;
1) Buy a 2 or 4 ohm sub-woofer (buy two one for each channel)
2) Buy 2 more identical sub-woofers so that you can connect in parallel and make the load 2 ohms ( so 3 woofers per channel)
3) Buy a different amp that is 6 ohm stable (THIS WILL BE A CHALLENGE)
Whatever you decide, have fun with it!!!
madurodave
madurodave
Memphis
Dj-torn
