how would i wire....
You don't need to use both sets of terminals if you don't want to.
If it's a mono amp, they're just connected internally. You could wire your VCs in parallel with each other (for 2 ohms per sub) and then one sub to each set of terminals, would be the same as running the subs in parallel, a 1-ohm final load.
so basically if i wire it in parallel to one terminal or two it doesnt change the impedance load. because i want the final load to be 1 ohm on the sub to get the most out of it.
i'm not sure i havent purchased one yet, i just wasnt sure how the mono amp had two terminals? that kinda confused me. But i guess if they are internally wired in parallel it wont affect the outcome. but i am looking for a pair of subs with an RMS from 800-1000W rms and a solid amp to match it with a total 1 ohm load
per sub, which is alot i know, but i am looking for good subs and a good amp to match it. so wat should i look for in the amp? the rms for the mono amp needs to be about 800W RMS 1 ohmX 1 channel correct?
wat mono amp would u suggest for a set of DVC 4 ohm subwoofers with around 800W RMS
badnewz122
badnewz122
Dallas, TX
badnewz122
