How would I wire a dual 2ohm sub to 1 ohm?
grillman6000
¿ G0t ThUmP ¿
hello. i have a dual 2ohm sub.....but the amp i have (kicker zx2500.1) is only stable @ 2 ohms.....
on the rockford fosgate website's wiring wizard if i have a single sub with dual 2ohm vc's u can only wire it @ 1 or 4 ohms....i need it wired at 2....
maybe u cood draw me up a quick diagram in the paint program or sumthing....please.
please help.....
thnx
-GrillZ
if you use one voice coil instead of its intended purpose of dual voice coils. then yes you could do that
Keeee-rect.
There is no way to get a nominal 2 Ohm final load using a single DVC 2 Ohm driver.
Period.
You can only wire it to 1 Ohm (coils in parallel) or 4 Ohms (coils in series) as depicted by RF's wiring wizard.
What kind of sub are we talking about here?
Doesn't the ZX2500.1 make some pretty decent power @ 4 Ohms since we're talking about a single sub here?
this is why you should do your research before buying //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
grillman6000
¿ G0t ThUmP ¿
grillman6000
Margate, FLORIDA
grillman6000
Mike Mccabe
