Foote
Alright, Ill try to be as specific as possible. Im installing in a 1990 Blazer, S10. Here are the 3 amps and what they will be powering:
2 amps that are built in to a "powered enclosure" (they are built that way). Well, its two seperate amps. 1 amp and 1 sub per encloser. They are cheap, visionix by the way.
and 1 amp that is sepereate from another enclosure (will probably be 2 kicker L7's.
Anyway, I wanna know how to go about wiring all these seperate amps...I have a battery-terminal-modification thingy "For gm vehicles" that has multiple holes to stick some amp wiring. But I dont see how to do the RCA cables especially as far as to my headunit goes (there are only enough outputs for one amp) And that goes the same for the blue turn on wire.
Also...grounding. Im not sure, will it be ok to have 3 seperate grounds bolted down on the same bolt?
Thanks for your help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
