How to wire Hifonics Hfi1500d mono w/ dual terminals
biabia87
UNFUKWITABLE
I have a Hifonics Hfi1500d mono amp w/ 2 Alpine type R's 2ohm and Im trying to wire both at 1ohm each so I can get the max outta my amp...my amp has dual terminals (2 negative's and 2 positive's)...If I wire each sub individually at 1ohm w/ the jumpers that are included, will I get the full 1ohm output from my amp if I use both negative and positive terminals on my amp for each sub?....The reason I ask is because on my amps manual it says that if I use all my terminals meaning both positive and negative, I will get a 2ohm output each minimum from my amp...Thanks for the responses Im not sure if Im doing this right!
And I agree however my subs owners manual says when I wire 1 sub I can get 1ohm impedance by using the jumpers...would this not work because of the fact that I have 2 subs even though Im wiring each seperately?
Gotcha! so I gotta wire all subs together internally, but they would need to be 4 ohm right to get that 1ohm impedance......and just use one pair of negative's and positives on ma amp?
biabia87
UNFUKWITABLE
biabia87
Phoenix, Az
Epic0318
