how to wire for future upgrade
fire919
Hello all,
i currently have two amps mounted all wires connected except power because i just got it
Stinger 0GA w/300amp inline....what do i do next?
**Future upgrade later will be to add a 2nd AmericanBass ph4000md and run both @ 1ohm
1 AmericanBass ph4000md.....to be run @ 2ohms (for now)
Rms at 1 Ohm: 2000 Watts
MAX at 1 Ohm: 4000 Watts
Frequency Response: 10Hz ~ 220Hz
Input Level: 5V ~ 0.2V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 40Hz ~ 220Hz
Switchable Bass Boost: 0dB, 6dB, 12dB
Fuse Rating: 150 Amp
1 Alpine pdx-f4
RMS Power Rating (@ 14.4V):
4 ohms: 100 watts x 4 chan.
2 ohms: 100 watts x 4 chan.
Bridged, 4 ohms: 200 watts x 2 chan.
can i leave the 300amp fuse inline or use a 250amp?
---------- Post added at 09:21 PM ---------- Previous post was at 09:20 PM ----------
thanks for responses by the way
The front fuse protects your wire not amps. The fuses on the amps protect the amps
hello again,
I did as instructed i connected my two amps w/ 0awg primary
from battey ---250a inline----to-----distro. block [150a/80a] ph4000md/pdx-f4 respectively---out---4awg to both amps. Now when i start my car the battery is dying, it barely starts. What did i do wrong? Never had any issue until right after i added wire.
FYI
Stock Electrical. Car fairly new. Music plays once car starts.
Is this a factory hu? Aftermarket? What are you using as a remote amp turn on? If you're just running a new run to the amps from the batt it shouldn't be killing the batt. Did you check for voltage drop with the car running and system full tilt?
this a a factory HU, and i use the 12 v ignition at the head unit for remote amp turn on. I did not check for any voltage drops. don't have equipment. But i did something else....i took off the 150a fuse @ distro. block. leaving only the 80a connected. Car started as normal. what do i do from here? any other suggestions.
fire919
fire919
the bronx,NY
fire919
vegang
vegang
