how to wire 2 titanium eclipse with rockford fosgate t1500 amp
  • 4
This is an amp for sale section.... And you need to provide more info... What coil configuration, and what kind of electrical you have to power that amp
//content.invisioncic.com/y282845/emoticons/wallbash.gif.1310150c49dd52e0fbe1813a0681e5c3.gif that amp needs power.... what kind of car is it in? How many amps is the alternator?
You'll need to have at least 2 gauge wire going to that amp and you'll need to install a big three upgrade to your underhood alternator and battery wiring. It would also be a really good idea to install a second battery, as that amplifier is capable of a lot more power than it is rated for. And in order for it to send power to the speakers, you have to send it power from the electrical system.
As for the woofers, model numbers would be helpful, since you're not knowledgeable about this stuff. And hey, it's fine that you're not knowledgeable about this stuff but since you aren't, always remember that the more information you can give us, the better we can help you along. I understand that you didn't know about voice coils but everything has a model number.... and eclipse makes more than one type of woofer so, you help us with information and we'll gladly help you with knowledge. ;-)
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
498
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
887
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
865
kevinkam22
kevinkam22
san diego, ca
kevinkam22
    May 12, 2024
Brendon Jenness
    May 11, 2024
