how to test a ground?
UNDERGROUND_BUM
ok so i tried to test my ground today with a DMM resistance(20k), and am not sure if i did it corectlly........ u tell me.
ok so i wired an 8 gauge strand to my - on my batt and ran it to were my amp is , i touched one end of my DMM on the 8 gauge wire and the other on my ground for my amp. and came up with a resistance of 0.00 is that normal to have no resistance? did i do this correctly ?
Did you zero the meter first? Even the test leads have some resistance.
Chances are that your DMM is not nearly sensitive enough to measure the resistance of a good ground. You also have it set to 20K which is 20,000 ohms. I really hope that you got a zero reading with that range set. Set it to 20 if you want to give it a try, but I still doubt that you'll get anything. 1/1000 of an ohm is in the ballpark of what you're lookng for.
how can i test if my ground is good then??
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
helotaxi
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
