how to reduce box CU
I would use foam, the expanding shit in a can for filling gaps. A block of wood will not be the best for your boxs internal aerodynamics. You can spray some foam in there and then once it dries shape it to what you need.
How will foam be good for aerodynamics? not to mention it has different dampening properties than a solid, non-compressing object (like MDF)
very true, also wiht wood you can calculate the amount of airspace you are taking up, with foam good luck
Exactly, I mean he said trim it down to your desired specs, which is acceptable, but then even if it was rigid enough, that would mean it's going to be just as bad for airflow as wood once you trim it down into a rectangular volume...
just throw some random shit in there.
maybe some shoes. an old tire. a box of cereal.
most FG enclosures are have very irregular shapes so i wouldnt be too worried about something like a piece of 2x4" effecting the boxes 'aerodynamics'.
Those will probably be fine in that enclosure anyway...the way you find out how big a piece of wood for .3 cubes would be is multiply by 1728, then divide by each dimension, in inches
So say you are using a piece of 3/4" MDF you want this size...1728 x .3 = 518, 518/.75 (3/4"mdf) = 691.2, now say you can have it be 30" long, divide by 30 = 23" = the width. So a 30 by 23 by .75" piece of wood would be .3 cubes
hopefully that process made sense...
yea no that makes sense... i guess the more i think about it ill probably just put them in the enclosure and call it done... seems like i could end up causeing more harm (damaging the enclosure, causing poor internal acoustics, etc) than the slightly smaller airspace is worth....
johnmatt
johnmatt
Western Massachusetts
johnmatt
