how to properly match a amps ratings to a subs ratings
yes, you can say that.....but still be careful with the gains
match with your ear, volume from your h/u, gains etc.
you dont necessarily need to match them up perfectly (ex: amp can be 1k and sub can be 800 wrms)
BTW...more headroom = better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok i understand. but if i wanted to be careful, and matched a 1000w amp with a 1200w sub, could that sub handle more power since it has a little bit more of power handling ? does a amp push out more than its rated to ? 1200w pushes 1400w or 1200w pushes 1200 w even ?
depends on the amp.. depends on the sub. for instance, the sundown that I have is "rated" for 1500 rms.. yet it puts out a good 1600ish rms (don't have the birth sheet). I have seen those IA DP handle WAY MORE than 1500 rms. it all depends my friend. just buy a good amp and puts out more power thatn your subs are rated for so you can have head room.
is the hifonics 1200w brutus overrated, if its 1200w will it put out 1300w
does overated mean the box says it pushes 1200 but it really pushes 1300, and underated means the box says it pushes 1200 but it pushes 1100, i just want to make sure i understand !
I beleive the concept of matching RMS ratings is an oversimplification geared towards those who don't understand how to find a speaker's true limits or how to effectively control an amplifier's power delivery. Just because an amp makes a certain amount of wattage more than what a speaker is rated for doesn't mean you have to deliver all of it, or that that speaker isn't capable of taking qutie a bit more than that during normal listening. IMHO you want the most power you can afford, worry about how much of it you'll actually send to the speakers later.
TERROR-TRON-74
TERROR-TRON-74
MURDER CAPITAL
eharri3
