how to install crunch amp to factory radio
  • Thread starter Unregistered
  • Live activity
  • Replies 1
  • Views 2K
If your factory HU does not have pre out RCA jacks, use the speaker leads from the factory HU and wire to the Hi-level inputs on the amp. 3m makes a connector called a "T-Tap" this little gem "taps" into the wire by surrounding and insulating the splice, complete the connection with the 4 leads from the amp, add spade connectors and plug into the side of the "T-Tap". A proven method although no substitute for pre out RCA's.
I hope this helps
Guest
toneddie
randy hagan
    Jul 15, 2026
