How to install a 1 Farad cap??
hmm... Set on ground, unzip pants, pee onto but try not to get it inside the screw holes, Charge by plugging into house wall socket, then sell on ebay to some suspecting ***.
Did i help?
first you run power wire back to wherever its goining then unscrew the nut ontop grab the original package and write return to sender then drop in mailbox and your all set
Heres how I install a cap: First, I charge it by hooking the positive and negative to the battery respectively. Then, I run a wire from the positive to my right nut, from the negative to my left nut (preforably with alligator clamps on teh sack). Finally, I jump in the shower.
thats why yours dont work you have the positive hooked up to the wrong nut
i wouldnt use a cap, i would sell it for money to buy wire for the big 3. but if your set on it, first off if it comes with a resistor then you will have to charge it. to do that you will hold one end of the resitor on the power wire and the other end on the power terminal to charge it up, then you will just run positive from battery to cap positive, and then ground the other terminal, then just run the wire from your amp to the cap. you dont have to run your ground to the cap just your positive wire.
LowLowBass
keep it simple
LowLowBass
SEATTLE, THE GREAT NORTHWEST
blackbonnie
