how to hook 2 amps up. massive n4 amps.
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
35thStangGT
35thStangGT
United States
mylows10
    May 23, 2024
    May 22, 2024
