How to cut holes for subs
>>SQL<<
Ok - I built many boxes back in the day but none of them were great and I am trying to do a better job now.
I need to mount my 2 - 10" sub in a double baffle.
Yesterday I cut both pieces of the double baffle out and glued them together.
Now I want to cut the holes for the subs.
I do not have a router or a circle jig.
Is there a easy way to mark the circle out. I thought of using string but it seems hard to get to the right size. I wish I had a wooden ruler but I do not as I thought I could drill a hole on one end and another small hole 1/2 the dimension of the cutout.
So what is an easy DIY of marking a perfect circle for the cutout.
Also did I mess up by gluing the 2 - 3/4" MDF panels together before I cutout the holes?
Thanks!
@pro-rabbit ???
I have always glued them first then cut them but I use the correct blade for the material thickness and go slow, as for marking it out use a thin piece of drop and drill two holes the correct distance apart just like it were a ruler.
Yea, that is not a good position to be in with both pieces glued together. Obviously since you have limited tools a jig saw is the only method and not really a great one for this situation. 1.5" of material to cut through is a pita though.
>>SQL<<
>>SQL<<
USA
Kangaroux
