Eddie Jones
i want to connect a fosgate r2d2 10 to a phoenix gold qx500.1d. to bridge do i use positive from left channel and negative from right channel?
Are they labeled left and right, or is there just two outputs? Also, are the inputs labeled left and right?if amp is 1 channel. why do they make 2 outputs on the amp a left and a right?
I'm sure theres a good reason for this. Can't think of one though, outside of for the sake of RCAsif amp is 1 channel. why do they make 2 outputs on the amp a left and a right?
unless you keep the gain turned all the way down it will likely cook that sub or the amp.. what would happen if I connect one set of those outputs to a side of the r2d2, and the other output to the other side of the sub?
