You need the plug. There is a plug that connects to the wires, then slides into that opening to connect them to the amp. Sounds like you are missing that plug. Shouldn't be hard to find.....they are on egay all the time. Contact robotunderground on egay and see if he has some you can buy.
Now //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif I've been calling it egay since WAY before I joined this forum.how come everybody calls it egay now??
No. That is a wire reducer, that allows you to, for example, fit 1/0ga wire into a 4ga opening. Those DEI amps need specialized plugs.anyways will this work? http://www.cardomain.com/item/STIS04ADAPT
Should have came with the amp. Either your amp accidently got skipped, or it was removed from the box before you received the amp. Where'd ya buy it?
That may be the problem, I bought it from ikesound as a refurb. Ive bought lots of refurbs before and they always came with everything I needed. I also didint get a bass knob with it. Maybe I should start a thread asking others who bought from ikesound?
