How should I run 8 runs of 0 gauge?
id start with 2 or 3 runs. cut a hole in the firewall and use expandi-foam to fill up the gap.
if you need more, you cna alwasy go back and another run or two or five.
That's what I'm thinking right now. I won't be even pulling but maybe 300-350a when I get to where I'm going right now, so I should be good.
I was told differently.
Here's the setup. The front battery will be a Batcap 3000, and about a 250 amp alternator. Would 2 runs be sufficient?
what exactly will you be running?
how much power
your battery bank
etc....
2 runs is usually enough for a daily driver.
then again there are plenty of other people on here with a ton of power in their daily drivers
what exactly will you be running?how much power
your battery bank
etc....
Well right now I don't need to upgrade but this is planning for the future here...lol
This is where I want to get to as of right now:
Batcap 3000 upfront, 2 or 3 2000's in the back. A 250a h/o alt. Then 2 eD 9.1s on two AQ HDC318s. Then I plan to upgrade hopefully to 2 AQ 2200Ds.
This is a daily driver but eventually I want to compete some.
yea, with a single alt set up like that, id do 2 runs. any more is just a waste of wire IMO. especially with the batt. bank in the back, like previously stated.
2 runs of each would be sufficient.
If you were running multiple alternators then a bunch of wire would be beneficial.
And like you said, you could always add more if necessary. Then again, if you already have the wire you may as well use it, though it's a bit overkill.
Edit: I should have better read what you're asking .
Here's the early progress of 4 of my 8 runs:
Where do you get the materials featured in these pictures and what is it called??
My only thing I would say here is that I would not trust zip ties to hold that up permanently. I am sure you have some other method to hold that conduit in place and the zip ties were just temporary. I just didn't want anyone else to think that would work.
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
