ultimate157
Engineering Student
Wood glue is a chemical bond; It reacts with the wood fibers to create a joint that is stronger than the wood itself. Wood glue won't bond to cured wood glue or caulking.why should i sand off all the caulking/glue from the tops of the sides before putting on the top baffle.?? its looking staright its my 1st box.
This will also level out your mounting surface so you won't have any gaps.
I've used the wal-mart carpet. It's pretty easy to use. 3M Super-70 adhesive works pretty well.i was thinking of some cheap fabric from walmart what material should i use that could stick well with that glue that you spray??
