How much total AMPs is this?
never use the "MAX" rating that is not an accurate rating. Always use the RMS rating it is more accurate and close to what most amps put out. I doubt it even puts out that power, personily i would stay as far away as Sony as posible. There price is cheap and so is there quality, for once with sony you get what you buy.many other amps out there that would power your kickers much better.
well seeing as its a sony a.... Maybe 800watts u'll see. SOny blows man... if u looking for a good amp look into Hifonics, US Acoutics, Viper(look on ebay), Crossfire. Alot more man.. do searching dont go buy sony, unless u really believe there good. I personally wouldnt buy one, but its your money. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. I just say search a little before buying.
Depends if you got a 2 ohm model yes. The amount of power given from the amp depend on the ohm of the sub.
Ex:
a DVC 4 ohm sub can draw a 2 ohm current or a 8 ohm current from the amp. you want an amp that can do around 800w RMS. If you get the 4 ohm DVC you want an amp that can do 800w RMS at 1 ohm or 4 ohm, or the 2 ohm DVC you want an amp that can do 800w RMS at 2 ohm or at 8 ohm.
krayzinsane
krayzinsane
Detroit
kickerlivinloud
