how much power should i go up to?
if you're truly giving them 600w each there is really nothing to gain by giving them more power. IF you could hear a difference it would be minimal.
A better box COULD make a big difference depending on what they're in now.
I don't see much improvement with a bigger box either. You could probably tweak it for a minimal SQ gain, but your box specs sound pretty good, and you're getting them enough power.
Could you improve it? Probably. But not significantly.
I would say you're getting about as much as you're going to get out of those.
I don't see much improvement with a bigger box either. You could probably tweak it for a minimal SQ gain, but your box specs sound pretty good, and you're getting them enough power.Could you improve it? Probably. But not significantly.
ok cool that is what i thought. seems like alot of people around are giving them like 750-1000 per sub
I'm not saying don't try, but to expect a drastic improvement would be unrealistic IMO. I think the most significant change would be the temperature of your voice coils and the increased odds of damaging the subs.
if you're truly giving them 600w each there is really nothing to gain by giving them more power. IF you could hear a difference it would be minimal.A better box COULD make a big difference depending on what they're in now.
Oh, there will be a gain:) But, the lifespan of that gain quickly shortens as more power is added:laugh:
You could always work towards upgrading and go for a bigger amp. Put your subs in series for a 4 ohm load and get an amp that puts out 1000 watts rms at 4 ohms. The SPL difference in losing 100 watts to each sub would be minimal. Then down the road upgrade your subs and wire back to a 1 ohm load for more POWA!
05fronty
SALT PETER
05fronty
conway,ar
jpexpc
michigan born
    May 14, 2026
michigan born
    May 14, 2026
