Currently running a class AB amp at 400wrms at 2 ohms. It has 60Amps worth of fuses on it as well as a 60Amp fuse on the wire. How much current would it really use? (constant 0db 50hz tone)
The class D amp I'll be using soon (APSM-1500) puts out 1500wrms and although it doesn't have fusing on it, it comes with a 100 amp fuse for the wire. I plan on drawing 1000wrms tops from it and as that is 2 thirds of what it's rated for, could I assume I wouldn't draw more than 66.66Amps?
I'm assuming there's a linear relationship here between power and current draw.
Cheers.
Cheers.
