How much is it worth?
comp2007
I have an Alpine MRP F-250 that is blown in channel 1 but channel's 2,3,4 all work perfect. I have my components hooked up to 3,4 now with absolutely no issues. I got a new amp, how much is this one worth with one channel bad?
Thank you
Details:
* 4-channel car amplifier
* 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
* 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
* 2-, 3-, or 4-channel output
* variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
* tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
* subsonic filter (15 Hz, channels 3 & 4 only)
* MOSFET power supply
* CEA-2006 compliant
* STAR Topology (minimizes internal noise and prevents ground interference)
* speaker- and preamp-level inputs
* preamp outputs
* gold-plated screw terminals
* fuse rating: 15A x 2
* 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
* 11-1/4"W x 2-3/8"H x 9-9/16"D
comp2007
comp2007
Phoenix,AZ
comp2007
BP1Fanatic
BP1Fanatic
