How much does ED NINe.1 really puts out @ 2ohms?
I've heard they are underrated and put out around 1050, even though I have no factual evidence to back that up //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
LOL this guy serious?? Go to icixforums.com They will know for sure. I GUARANTEE it is not 900 watts though. Hey Puppiechow, can you prove it puts out 900-1k? NO, all you did was make a statement, jacka$$
i have the 9.1 run at 2 ohms and it draws 42 amps so im guessing thats around 800-900 watts but thats without the efficeincy worked into the equation. it does its rated power and does it right. no problems with mine as of yet.
dont forget. thats 8-900w if powered strictly at 2ohms on load resistors...
more like 500w after impedance rise and factoring in daily music. wont be getting a REAL 800~1kw //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
42 amps running at 14.4 volts means the amp is creating a total of 604.8 watts,
to calculate the amps efficency, lets say it's very high at 80% efficent, you are losing 121 watts through heat, which equals to the amp is only outputting 483.8 watts to the speaker terminals.
these figures are quite optimistic also, your system voltage might be lower then 14.4 volts, and I highly doubt the amp is 80% efficient
Then that is true for every amp that is rated ar 900 watts @2ohms. I would compare it to every amp that is rated at 900 watts @2 0hms in this case. Either way it is all relative.
digital mint
Open up
digital mint
Vancouver BC, Canada
DFW40
michigan born
    May 14, 2026
michigan born
    May 14, 2026
