How much am I sending the speakers?
You've bi-wired them, not bi-amped them. And not a good bi-wire, either. A true bi-wire has two sets of wires coming from a single output on the amp, not a single wire split at the crossover. Bi-amped uses two channels on the amp.
Now, how the crossover is wired, I'm a little shakey. I think if you set the jumpers in the crossover for bi-amp, then you'll basically have two 4-ohm loads, which you have wired in parallel, which means a 2-ohm load to the amp. So according to your diagram, it looks like 100w.
In the picture it looks like you have a 4 channel amp. if so bi-amp them use channel 1 and 2 to run the woofers and use 3 and 4 for the tweeters. make sure you take off the jumper on the crossover. it would be 50 x4. unless 3 and 4 are running another set of speakers.
Yeah, its a 4ch amp but I am only using 2 channels because I ditched the rear speakers to have just a frontstage.
I was thinking of selling this amp and getting a 2ch, better amp.
Would it made a huge difference if I bi-amped the crossovers using this amp (rf p4004) or got a new amp that could send more rms?
Edit: so right now each speaker is receiving 50w right?
Konstantin
Konstantin
Chile
Konstantin
michigan born
    May 14, 2026
michigan born
    May 14, 2026
