how many watts can a 80 amp agu fuse hold?
If a fuse that is rated 80 amps allows more than 80 amps for any extended duration, well, ya might have to use that pretty fire extinguisher.
Umm, in a sense, yes they do allow current to flow. But they also stop the current too! I think the term "Overcurrent protection device" explains what I mean. :p
An 80A fuse doesn't blow exactly at 80A of current draw. It'll allow quite a bit more in the event of a short until it heats up enough to melt.
for those who feel like arguing about it- continue. for the op-
the best answer for you is- what is the recommended fuse size for you amp? what is the recommended fuse size for the power cable size you are running? (use whichever is smaller). Use a search if you can't find any of that information.
more important than efficiency is music's crest factor.
An efficient class D amp that can produce 1000w rms at 14v on a test bench playing 0dB sine waves at full volume will draw around 90A.
That same amp playing music at full volume will draw 20-30A rms.
An average class a/b amp capable of 1000w would draw around 120A for tones, 30-40 for music.
I totally understand. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i usually match the wire with the current demand and install the fuse according to the current draw of the amp.. so if the amp has a 150 a fuse i run either 4ga or 1/0 depending on the length of the car.. and install a 150a fuse under the hood..
babaganoush123
babaganoush123
chicago
SethPhillips
