How many batteries for how much power?
CJL
oZone
I found this chart on another forum and i was wondering if i was running ~2100wRMS i would need atleast 1500amps form my batteries,so would a Kinetik HC 2000 be good since it gives 2250amps?
EDIT: The chart came out ****ed up //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Total RMS Minimun Total RMS Minimum
Wattage of Battery Wattage of Battery
System Current System Current
0 - 50 675 1100 - 1200 1250
50 - 100 700 1200 - 1300 1300
100 - 150 725 1300 - 1400 1350
150 - 200 750 1400 - 1500 1400
200 - 250 775 1500 - 2000 1450
250 - 300 800 2000 - 2500 1500
300 - 350 825 2500 - 3000 1550
350 - 400 850 3000 - 3500 1600
400 - 450 875 3500 - 4000 1650
450 - 500 900 4000 - 4500 1700
500 - 600 950 4500 - 5000 1750
600 - 700 1000 5000 - 6000 1850
700 - 800 1050 6000 - 7000 1850
800 - 900 1100 7000 - 8000 1900
900 - 1000 1150 8000 - 9000 1950
1000 - 1100 1200 9000 - 10000 2000
i think the way kinetik has it set up. you use the number of batties for the number of watts you are using. or at least that is what they reccomend. like the hc 600 is for 600 watts and the hc 2400 is for 2400 watts and so on. but i have seen those lil 600's hold up to some pretty big amps and last a good lil whiles before they get to the point where your lights start dimming real bad and such.
100% correct but for daily use and lack of trouble a 2000 should do pretty good of course a 2400 would be better though. not saying you would notice a huge difference but you would have better reserve capacity with the larger cell.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
CJL
CJL
oZone
audiolife
    May 12, 2024
Brendon Jenness
    May 11, 2024
