helotaxi
Kilroy was Here
The voltage measured across the terminals of the batteries is 14V or whatever the alt is putting out, however, as soon as you exceed the capacity of the alt, and the reserve of the battery is needed it does not discharge at 14V because the battery is only 12V and that is the voltage that it discharges at. The system voltageSo your batteries are not @ 14V with the car running....thats not correct....You know this.
is going to be the lowest voltage of whatever sources are supplying current to the system.
Sure it does, but so does multistrand wire. The capacitance of a battery will affect its charge and discharge but it is not sufficient to hold a reserve of current and is not relevant to this at all.Ok so you think a battery has no capacitance?
It is filled by creating a potential difference across the internal plates. Thsi intial charge for our purposes is usually added using the battery and an inline resistor to limit the initial spike in current that would occur if you were to just hook an uncharged cap up to a battery.What do you think fills a capacitor ?
They are similar but nowhere near the same. The relevant difference for the purposes of the discussion here are their behaviors when it comes to holding a charge. Assume that we have a car with two batteries and a cap installed. If we checked the voltage across the terminals of each of these with teh car running, we would get whatever the voltage coming off the alternator is. If we were to disconnect one of the batteries and the cap from everything else and then measured the voltage across them the battery would read something in the mid 12V range and the cap would still read whatever it did before. As we place a higher demand on the car's electrical system and begin to exceed the current output of the alt, the system voltage begins to drop. Between 14.4V and and whatever the battery's discharge voltage is the battery is contributing absolutely nothing to the situation. The battery is not going to provide usable current until it's working voltage is reached. Because a cap is truly charged to the working voltage of the system, it will begin to immediately discharge once the system voltage drops below the highest voltage. If enough power is drawn that the alt and the cap can't fill the gap and the system drops to the battery's working voltage then the battery will kick in.When you first charge one - is the car usually on ...... No. A battery and cap are similar - one holds a reserve and by adding a second you doubled the reserve (assuming both batteries are equal) Adding a cap just adds capacity to hold power that is already in the system. Its like an air tank for airbags - it did not make the air but will hold it and release upon demand.
How can a battery stop any disco effect if the cause of the disco effect is the difference between the alts working voltage (which has to be higher than the battery's for the battery to be charged by it) and the battery's working voltage?A battery will certainly stop any disco light or slow fade. You have to look at the whole picture, not just one part. Everything works as a system. With the car on the entire system operates at 14V. You cant say that this burst came from the ALT or this low note was powered by the battery (unles car is off, we know that) All parts are daisy chained together and therefore react together.
More reserve only means that you can dip into it for longer before the thing falls completely on its face. If I discharge 20Ah from one battery or from 200 batteries, I still have to put back 20Ah. The amount I have to reload has only decreased as a percentage of the total reserve. The alt just "sees"s that it has to replace 20Ah and if a bunch of batteries are wired in there then it will, as a result of the much decreased ESR compared to one battery, have to put it back much faster.Again, second battery - the ALT does not need to catch up. You see the ALT and batteries are directly connected, so while the ALT creates the 14V operating voltage, large spikes come from a battery and the ALT adjusts to reload for the next burst. More reserve means less to reload.
If a person is regularly running the car IVO redline then they aren't really a candidate for an overdrive pulley systme because not only will they trash the alt but they won't even be getting a benefit from it. If someone was so inclined, they could devise a system that would drive the alt at a constant (or relatively so) RPM independant of engine RPM.I meant it is harder on the ALT but it will add a load to the engine, if you do over drive your ALT it could cause premature failure. If in a car that is taken to redline often, you could possibly exceed the bearings rpm tolerances (this is not likely, but in extreme cases like we seem to be talking about - could really happen) Bearings go on units all the time just from time, excessive heat could break the grease down premature.
