How many ANL fuses do I need?
give each amp its own run of wiring directly from the batteries and fusing
250-300a fuse will be fine
if all the batteries are together in a group dont bother fusing them. fuse from the front to back runs though and from the batts to the amp. i.e. 2 fuses near front batt within 18 inches and rear batt within 18 inches, then 18 inches from rear batts to each amp would be 6 fuses total. dont bother fusing the alternator imo but you can
the 4 channel only needs a 50a fuse, they dont use much current at all
you need dedicated ground runs to the rear batteries and then to the amps. absolutely necessary for that power
Mike Waters
Mike Waters
Middleburg, Florida
wew lad
vegang
vegang
