those amps i dont beleive are 1 ohm stable , jus 2 ohm. and you can run 3 @ 2.66 ohms, but it wont be getting enough power as say running 1 12"with recommend power
the only way u can wire 4 to those amps and get a 2ohm load...is to get the dual 4ohm coil type r's and wire them in series which will bring the speaker 2 8ohms and then wire all 4 in parallel and the amp will see 2ohms
