How low can I go with a crossfire vr4000d (voltage)?
should try to work on your grounding. should match your power wire runs. and maybe try 1/0 to the amps with 1/0 - 4awg wire reducer
jbizzle has a trailblazer too, and he said when he ran a ground from the front it was giving him problems. So I was thinkin of just ding several ground in the rear. I was going to try and fit 1/0 into the amp too, but it may be a tight fit, maybe just trim some of the copper. Do ya think I would be ok to ground in the rear only. I don't want to ground up front and come up with a prob andrip it out. Keep the input coming, I don't want to mess this up
i have no idea why someone would have probs gounding directly to the batt with 1/0 ppl do it all the time with multiple runs for power and ground wires
he said his amp wouldn't turn off and subs were pulsating, not sure why the ground would do that? So if I leave the 1 neg from the front to the rear in, and I also ground again in the rear, should I be ok? I don't have enough 1/0 to do another run of -.
...what should I do, I thought I would be ok doing this, as I talked to some peeps b4 about it
da box king
da box king
Portland, MI
da box king
